Not holding boost
My stage one saph was boosting to 18psi. It's now only holding 13psi. I'm guessing the spring in the actuator is knackered - possibly due to fact I had a hose split recently allowing turbo to boost to 30psi. It only did this twice before I realise but could this have weakened the spring?
If it is the spring will I need a new actuator or can u carefully adjust on the rod until I get back to 18psi?
easy, just make sure you preload the new actuator.
start off low and keep shortening the rod until you reach your desired psi, 1 turn on the actuator rod will roughly equate to 1 psi. you will have to take it out for a run each time.
It depends on if it's mapped for it or not, stage 1 is circa 15PSI but it depends entirely on the setup, Gunship for example uses stock components but can run near stage 3 power!
You can't simply just change injectors as the software has to be progremmed for the specific injectors, different pulse widths etc!
Martin
Martin
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
