Display driver ATI radeon family stopped working
and has successfully recovered is the message I constantly get if I try to watch videos/you tube mainly on my PC. It is since I installed windows 7 64bit.
Any ideas guys?
Any ideas guys?
Go into driver properties in control panel somewhere (im not to familiar with windows 7), find the card in the list and update the driver. could be worth trying that with all your drivers since you've upgraded to 7.
Passionate about fords
START > CONTROL PANEL > HARDWARE AND SOUND > DEVICE MANAGER > DISPLAY ADAPTORS
Once you have followed the above steps itll show which card you have installed, write it down mate, then i think itll be best if you do the following
START > CONTROL PANEL > PROGRAMS > UNINSTALL A PROGRAM
Once in there you should see a video driver, it should be named either ATI or AMD as they own ATI. uninstall that and anything else ATI gpu related ie control centre etc then reboot.
Now go to the AMD website which you can find here
http://support.amd.com/us/gpudownload/Pages/index.aspx
Add your info into the fields and itll bring up the correct driver for your gpu and os.
If you need any further help give me a shout.
Dave.
EDIT: Probably best to get your correct driver downloaded to your desktop before uninstalling the current one then everything wouldnt of gone massive on your desktop lol.
Dave.
borboyous
Aug 22, 2015 11:17 AM
