ofab map sensor superssor
Old Mar 17, 2011 | 01:00 PM
Paul81's Avatar
Paul81
Default ofab map sensor superssor
can anyone tell me if you need the superssor on a ofab loom gettin mixed feedback some ppl say you gotta have one others say you dont an if i dont how would you get round it plz help
Old Mar 17, 2011 | 04:42 PM
JonathanJ's Avatar
JonathanJ
The way I look at it is that Ford would not fit one if it was not needed as we all know they would not spend money needlessly , but then there is a lot of cars out there running without one that seem to run without an issue , the way I have done it so you can add it in later if you find one is get a faulty speed sensor and cut the wiring from it to the plug , you can then join the required wires and leave the main loom un-mollested , or you could just cut and join wires before suppressor plug if you canot find the 3 pin plug required
Old Mar 17, 2011 | 10:35 PM
Paul81's Avatar
Paul81
so it can be run with out do you no wot wires need to be joind up
Old Mar 23, 2011 | 12:28 PM
JonathanJ's Avatar
JonathanJ
Sorry a bit slow to reply , forgot this was on going , I assume you have the 3 way plug up near the ecu plug that the suppressor goes into , if so there are 3 wires in it , a yellow one that comes from the MAP sensor and a brown/yellow that goes to pin 27 on the ecu , these need to be connected together .
I find it best if you make yourself a "jump lead" up , I make mine from a speedo sensor wire as it has the yellow wire in the correct position , then if you want you can just solder the green and yellow wire together and tape up in a termination bundle and tuck it away , what I do is make a small loom up using the yellow wire and plug , I remove the red and green wire , fit a Brown/yellow wire in place of the green , use a blanking grommet in the now spare hole , then solder the wires together and then heat shrink them , have an example pic if required as I did one today in case i decide to do a guide in the future .
Old Mar 23, 2011 | 06:11 PM
Paul81's Avatar
Paul81
Cheer mate nice one i should be alright on the pic no wot u mean just needed to no wot wires to connect up il make meself up a jumper lead so if i can get a superssor i can swop it over thanks again
Old Mar 23, 2011 | 06:25 PM
JonathanJ's Avatar
JonathanJ
That is why I do it a jump lead way , I do have a spare one but if they both fail I have a jump lead to fit , better a non suppressed signal than non at all
Old Mar 23, 2011 | 08:36 PM
Paul81's Avatar
Paul81
someone said that MSD do the superssor think i mite have to give them a call
Old Mar 23, 2011 | 08:43 PM
JonathanJ's Avatar
JonathanJ
I think they did , but it does not show in their shop for the FRST , but then it is worth a phone call
Old Mar 23, 2011 | 08:59 PM
Paul81's Avatar
Paul81
thats wot i fort at least il no either way
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
