2.8 Cologne problem
Old Mar 17, 2011 | 11:56 AM
Woolk's Avatar
Woolk
Default 2.8 Cologne problem
I have a problem with the 2.8 Cologne engine I am running in my Mk2 Escort. It starts perfectly when cold and perfectly when hot, but if allowed to cool down a bit after running then it turns over real slowly as if the battery was flat. I have tried advancing and retarding the timing but to no avale. Anybody any ideas?
Old Mar 18, 2011 | 12:11 AM
bangerboy33's Avatar
bangerboy33
Is it Carb or injection?
Old Mar 18, 2011 | 07:52 AM
Either a bad connection or the starter is a bit dicky.
Old Mar 19, 2011 | 11:34 AM
Woolk's Avatar
Woolk
Its Injection
Old Mar 20, 2011 | 10:00 AM
What causes the engine to spin ?, STARTER MOTOR, it doesn't give a shit whether you are mfi efi or carb.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
