2003 Fiesta Mk6 Passenger Electric Window Problem - does not work
Hi
This week I picked up a 2003 Fiesta Mk6 from an auction.
Neither electric windows worked, except the drivers after I removed and refited the electrical block in the door shut and after I punched the door following advise I saw elsewhere on the internet!!
Still the passengers window does not work. Despite doing the above.
Now, the passengers window switch on the drivers side does nothing.
But on the passengers side, pressing 'UP' you can here a faint click like you'd usually get BUT nothing when you press 'DOWN'.
Could anyone please help ?
Any advise would be gratefully received.
Thanks !
Thanks !
when you press the button do you hear the motor turn?
if so plastic gear is broken as there is no clutch and stiff rubbers can cause this.
if it's not turning lub the rubbers and check again, if it still isn't working you need to access the motor to see if there is voltage there when you operate the switch to diagnose.
2v when pressing 'DOWN' - Is this normal ?
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
