Best turbo for stage 3 chip?(pinto)
for a fast road/track car what turbo would you use? wanting around 330-350 reliable bhp, cossie bottom end with pinto head and efi inlet manifold!
cheers
cheers
cheers pal thought it would be good saving money though so cheaper alternative is a chinese t04e for £150, i was lookin at all sorts like chinky t70 or gt30 or even a holset!
Sometimes its better to spend a little more in one go then buying 2 or 3 replacments if tge turbo goes bang.. The garret t34 has been tried n tested for years mate and it is a awesome turbo
im interested building a pinto turbo trying to keep it on a budget and use some parts i already have,i've got a T3 from a cosworth and a couple that came from ERST and FRST one of them will be going on a 205 bottom end with an efi head any idea what kind of power im looking at with a few mods cam vernier megasquirt sorry for the hijack and good luck with your build.
Agree 100%, T34.48 cars are superb as a road car, has the punch of the T3 but makes that bit more BHP and is a hoot @ 32psi peak, really loved that setup on my old 3dr...
As above, imo I can't see the head/manifold being able to flow well enough for the power you want as standard, thats the same as a slightly fettled YB makes! Real world more likely 250-300HP at the most I should think with porting etc.
Martin
Martin
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
