Whats this?
Old Mar 15, 2011 | 01:08 PM
tanksturbo's Avatar
tanksturbo
Default Whats this?
hi iv recently got my escort turbo running after two years but the turbo isnt kicking in i couldnt get the beaing to spin so i took it off and sorted that out but theres a valve on the turbo which i havent connected but i dnt no if i need to??????
Old Mar 15, 2011 | 01:31 PM
JonathanJ's Avatar
JonathanJ
The brass tail is the feed to the actuator that controls boost , it should have a pipe on it that either goes to the amal valve or a manual bleed valve then off to the can
Old Mar 15, 2011 | 01:43 PM
tanksturbo's Avatar
tanksturbo
so i need a pipe on tht to the actuator??
Old Mar 15, 2011 | 03:21 PM
rog's Avatar
rog
How did you "sort" the bearing just out of interest, new turbo?
And yes, there needs to be a pipe connected or you will have no boost.
Old Mar 15, 2011 | 03:50 PM
JonathanJ's Avatar
JonathanJ
The problem is with no pipe you will get massive boost , unless the actuator is adjusted with no preload and the wastegate is pulling the actuator rod then it will still act the same , check your wastegate is seating correctly and the actuator is adjusted with about 3/8" preload as a starting point
Old Mar 16, 2011 | 09:31 AM
tanksturbo's Avatar
tanksturbo
all sorted now!! there was a piece of metal stuck which was from my old engine.then sprayed it with wd40. i took her for a spin yesterday for the first time in two years and i love it its quick!!
Old Mar 17, 2011 | 12:41 PM
rog's Avatar
rog
I'd be surprised if you got much boost with the pipe off, you may aswell drill a hole in the housing.
Old Mar 17, 2011 | 05:08 PM
JonathanJ's Avatar
JonathanJ
The amount of air that escapes through the hole is small in comparison to the amount of air that the turbo can produce dont forget if you are running half a bar of boost at 6000 rpm that engine is consuming a lot of air , it is there to give pressure to the boost control side of actuator , not a volume of air .
Once had an RS Turbo that the pipe had fallen off , it was boosting massively about 1.5 bar and it was not really noticeable that the pipe had fallen off in any other way .
Old Mar 17, 2011 | 05:31 PM
martysmartie's Avatar
martysmartie
As said it's actually the other way round, with no pipe connected you will run more boost than desired and so you can actually destroy your engine with it disconnected! As standard it would be plumbed to the Amal valve.
Martin
Old Mar 18, 2011 | 04:23 PM
rog's Avatar
rog
Ah ok, maybe i should do that in my saph, easy way to compensate for the boost leak!
Old Mar 18, 2011 | 05:25 PM
martysmartie
If you have a leak you really need to sort it as this will result in premature turbo failure!
Martin
Old Mar 19, 2011 | 09:55 AM
rog's Avatar
rog
I would have to drive it for that to happen!
