Injector Question...
Old Mar 14, 2011 | 09:42 PM
Churtz's Avatar
Churtz
Default Injector Question...
Hi all.
I've had my 2.0 blacktop running n/a in my mk4 fiesta for a couple of months now so I'm ready to push on and get the supercharger fitted.
It's running on megasquirt, and I have water Inj to be fitted when the s/c goes on.
Question, I planned to use Nissan 200sx injectors, and the reading I've done says to use the zetec o-rings. However when I tried it they split when pushing the injectors into the zetec rail. Anyone had a similar problem or are we thinking slightly perished o-rings?
Thanks
Matt
Old Mar 15, 2011 | 10:30 AM
Did you oil the injector seals ?, if you sprayed WD40 on them this will cause them to dry out and not go in, a little oil and they will simply fall in nearly!!
Old Mar 15, 2011 | 12:33 PM
Churtz's Avatar
Churtz
In the heat of the moment with no oil to hand I went for a bit of good old saliva! Haha. Will try new seals and soak in oil first.
Thanks once again Tabetha,
Matt
Old Mar 15, 2011 | 09:09 PM
"no oil to hand"!!
The engine has some in it, get some of the dipstick.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
