Needs help with locking wheel nut not got correct socket for it
Old Mar 12, 2011 | 06:23 PM
shortymaz92's Avatar
shortymaz92
Default Needs help with locking wheel nut not got correct socket for it
Hey was just wondering if anyone new how to remove a locking wheel nut without the correct socket, my mate brought some new wheels and couldnt remove his current wheels due to not having the right socket... lols on him
Old Mar 12, 2011 | 06:25 PM
carcollector's Avatar
carcollector
weld a nut on it or get a special tool to remove it
Old Mar 12, 2011 | 06:29 PM
tooly80's Avatar
tooly80
tooly80
hammer an old socket on to it but be careful not to hit your wheel.
D16PJM's Avatar
D16PJM
i normally wack a slightly smaller socket over the nut, always works but you need 4 sockets and they are no good after.
Old Mar 12, 2011 | 06:35 PM
Retro Al's Avatar
Retro Al
RWD IS KING
You can buy sockets at halfords just for the job
Old Mar 12, 2011 | 06:41 PM
shortymaz92
The nuts are 17mil so what size socket should i use to wack onto it ?
Old Mar 12, 2011 | 06:44 PM
carcollector
try a 10mm
no seriously theres special tools for that, if halfords has it its worth buying it there
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
weld a bolt on to them them brake the bolt of and chap on one of them fansy irwan sockets and jobs a goodin
Old Mar 12, 2011 | 06:47 PM
shortymaz92
Originally Posted by carcollector
try a 10mm
May head up there tomorrow then cheers fella
Old Mar 12, 2011 | 06:53 PM
archy's Avatar
archy
you can get wheel nut removel set from screw fix for bout Ł20 mate
Old Mar 12, 2011 | 06:57 PM
shortymaz92
I just gave my mate a bell and he said he'll check them out to but most probably go to halfords, cheers for help though fella
Old Mar 12, 2011 | 07:20 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
im suprised nobody tryed this...i got a chizel small one and put it between the nut and rim then smacked it with the hammer [ carefully without damaging the rim]it loosens and slowly turns loose! then take it off
Old Mar 12, 2011 | 07:21 PM
MO' BENT RIMS
put it back on same way
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
IanC
Sep 5, 2015 09:38 PM
hopper350
Sep 4, 2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
