Focus Hydraulic Tappets
Old Mar 12, 2011 | 10:57 AM
dougieliving's Avatar
dougieliving
Default Focus Hydraulic Tappets
Hi
Ive just removed my cylinder head and at my work place a fellow engineer came over and turned the cylinder head over to see where my head gasket had actually failed. As he did this the tappets fell out and now I dont have a clue where they go as they are all different thicknesses. I would really appreciate if some one could help. Thanks
Old Mar 12, 2011 | 11:27 AM
btcc93's Avatar
btcc93
Focus do not use hydraulic tappets they have solid lifters with shimmed adjustment.
Old Mar 12, 2011 | 01:01 PM
martysmartie's Avatar
martysmartie
What he ^^ said, they have solid lifters and are adjusted by shims.
Martin
Old Mar 12, 2011 | 02:01 PM
dougieliving
Alright cheers mate, but do you know what order they go in? because ive got some saying 0,375 SOME 0,290 and i just dont know
Old Mar 12, 2011 | 04:29 PM
Sp3no's Avatar
Sp3no
Every one of them shims were unique to each lifter so you now have no idea of which goes were. Complete re shim for you, lots of measuring with feeler blades and get your calculator out. I would be tempted to buy new also, an inccorectly shimmed head results in top end noise and a lack of power
Old Mar 18, 2011 | 06:14 PM
project rs's Avatar
project rs
you can also run theses on hydrolic lifters but a little bit of machining is required
Old Mar 18, 2011 | 09:14 PM
martysmartie
I don't see why you would want to tbh, obviously Ford thought the same as the Zetec-E until May 1998 were hydralic then they changed. The adjustment is 100K, hydralic lifters are inferior in my opinion.
Martin
Mile30
69
May 13, 2017 08:44 PM
IainRS1700T
Sep 25, 2015 06:44 AM
davidfordrs
Sep 21, 2015 04:23 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
