ford puma body panels
being a mechanic thats what i thought ... dont know much about this car but was told the fault was poss the vvt solenoid valve failed... but my opinion is that they attempted a cam belt change or belt slipped.....
In trying to get my Ford Puma repaired nobody seems to be able to supply a rear wheel arch replacement. All that is on offer is a rear quarter panel and to make a proper job this could cost £1000 per side. Now considering that all Pumas suffer from the same fault ( well done Ford!!!) then there must be a premium market for wheel arch replacements. Can you help or point me in the direction of the panel makers so that I can try to resolve this and help other Puma owners to keep their cars in good condition. This is the only fault that occurs on what is a great car
apparently they use peugeot 206 front wheel arches, as they fit the opposite side for the intended use, quite interesting
http://www.pumapeople.com/forum/inde...owtopic=101172
borboyous
Aug 22, 2015 11:17 AM
