2.0 Black Top Zetec
hi here is my 2.0 zetec it comes with flywheel,waterpump,rocker cover,head with all bits e.g cams etc, block, pistons with rods,new bearings fitted and small ends, perfect crank engine before rebuld only did 48k.
also with is a inlet manifold for dcoe carbs/TB's, cambelt, and new head bolts.
just needs a head gasket to finish as ive had to use it on one of my track toys
need the lot gone 300pounds
will upoad pics soon
cheers
cheers
