radiator leaking!!!
Old Mar 8, 2011 | 10:50 AM
Ian-North-London's Avatar
Ian-North-London
Default radiator leaking!!!
hi all,
found out this morning my radiator is leaking, ive used rad weald before, proabably a couple of years ago now, can you use it again or does it look like i need a new one?
the radiator is for a 2.0ltr twin cam
thanks
Ian
Old Mar 8, 2011 | 11:30 AM
Ian-North-London
http://www.discount-cooling.co.uk/Radiators_D69558.html
would this fit on m 2.0ltr twin cam
thanks
ian
Old Mar 8, 2011 | 12:33 PM
martysmartie's Avatar
martysmartie
TBH any sealent like that imo is just a temporary fix it's not a solution, you could try it again but the fix will be to get the radiator reconditioned or replaced. The one you mention should fit I should think, it dosen't mention though, only other engine it can be for is a Pinto although these may be the same?
Martin
Old Mar 8, 2011 | 07:09 PM
Kalimex K-Seal is the stuff to use if any, I personally know of engine blocks that were leaking over 5 years ago sealed with this that still do not leak, if it works it works 100% and within 10 minutes, you can change the anti freeze and don't need to renew the sealant.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Fudgey
21
Sep 30, 2015 06:19 PM
