....what causes
Old Mar 7, 2011 | 05:31 PM
Ima Racing's Avatar
Ima Racing
Default ....what causes
....going fast braking and the steering wheel shaking, only when stopping from high speed fine from normal no veering etc???
Old Mar 7, 2011 | 05:34 PM
Magnum PI's Avatar
Magnum PI
I think it may have something to do with the wheel balancing mate. I'd get it checked
Old Mar 7, 2011 | 05:35 PM
fordsportjay's Avatar
fordsportjay
warped brake discs.
Old Mar 7, 2011 | 05:38 PM
dazoriginal's Avatar
dazoriginal
prodigal son
aye warped discs
Old Mar 7, 2011 | 05:42 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Or warped hubs
Old Mar 7, 2011 | 05:48 PM
JonnyBravo's Avatar
JonnyBravo
Slightly warped discs and maybe a combination of that and worn bottom ball joints.
Also check the steering coupling if its a rubber one as although that wont be a cause it can make them feel odd when their worn.
Ima Racing's Avatar
Ima Racing
....no, discs are fine only down 2000miles...i changed the wheel studs for longer ones so best do a retighten!!!!!!!!!!!! Didnt do it before that or on the std brakes
Old Mar 7, 2011 | 05:50 PM
Ima Racing's Avatar
Ima Racing
...i noted the end anti roll bar bush was a bit fucked could that cause it?...Got polyrace ones to fit tommorrow.
Old Mar 7, 2011 | 06:56 PM
rstoughy's Avatar
rstoughy
What pads you running?
Some leave a deposit on the disks (DS2500's for example) during "normal" use that can cause this.
soloution can be a very hard brake from a high speed to standstill as this will burn off any deposits on the disks.
Old Mar 7, 2011 | 07:08 PM
gibbo frst's Avatar
gibbo frst
mine did this but didnt feel too bad as the worn steering coupling bush must have taken the worst away but after changing the bush it got far worse.. just brought new rotors to fit so hopefully will cure the problem.. ive managed to end up with warped disks on a car with 20 miles on the clock.. golf gt luckily not mine tho..
Old Mar 7, 2011 | 07:14 PM
S1's Avatar
S1
Did you give the drive flange a damn good wire brushing before putting the discs back on? Crap trapped behind the disc can cause the same symptoms as warped discs.
Old Mar 7, 2011 | 07:49 PM
It's Czech Mate's Avatar
It's Czech Mate
Bushes
Disks
Runout on hub
Fucked steering rack
etc etc
Old Mar 7, 2011 | 10:04 PM
Cozziekid's Avatar
Cozziekid
Warped discs or worn compliance bushes (where anti roll bar goes through bottom arms).
MJ_RST
41
Jul 22, 2010 11:47 AM
Lee_R21Turbo
Jun 3, 2008 01:12 PM
SapphyMike
Oct 13, 2006 04:27 PM
ImaRacing 700
May 20, 2005 07:48 AM
