Gear change
Old Mar 6, 2011 | 06:36 PM
burnhamshaun's Avatar
burnhamshaun
Default Gear change
After fitting burton power short shifter and changing clutch gear changes seem some what intermittent sometime gears will select ok other times when I come to a stop I have to pump clutch peddle to get 1st also since changing clutch speedo does not work it's a paddle clutch
Old Mar 7, 2011 | 08:18 PM
burnhamshaun
Come on fellow enthusiasts give me a helping hand here
Old Mar 7, 2011 | 10:44 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
what clutch?
is your ratchet and pawl in good condition?
if a heavier duty clutch have you done the manual pedal conversion as in the ap website?
Old Mar 8, 2011 | 05:34 AM
burnhamshaun
Yea it's an ap paddle clutch no haven't done peddle change what's engulfed with that then As I might have to do that it's hard to believe that a peddle could make any difference tbh
Old Mar 8, 2011 | 07:43 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
look on the AP website as it tells you what is needed for it.
the ford ratchet and pawl are too weak for a heavier clutch setup, manual is way better.
Old Mar 8, 2011 | 08:50 PM
burnhamshaun
Ok cheers mate will have a look on pc at the weekend as can't seem to find anything on the website on my iPhone is it a hard/costley job
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
marky_g
Sep 12, 2015 04:26 PM
Adam Graham
Sep 6, 2015 06:04 AM
