focus mk1 maf sensor
Old Mar 3, 2011 | 05:02 PM
focus-rob's Avatar
focus-rob
Default focus mk1 maf sensor
hi i have a 1.6 zetec se focus mk1 51plate. been having problems with accelration lately so i went to clean the maf sensor but i don't seem to have one and there is no wiring near by to even indiacate there should be one can anyone shed any light on this please as im not sure wether it should have one or not
Old Mar 28, 2011 | 05:45 PM
focus-rob's Avatar
focus-rob
bump!!!!!!!!!!!!!!
Old Mar 28, 2011 | 05:57 PM
tezza68's Avatar
tezza68
Your focus has what they call a tmap sensor that replaced the maf sensor, its located on the inlet manifold.
What problems are you having ?? have you checked the emission pipe behind the inlet manifold ( T shaped) as they have a tendency to go baggy and split causing running problems.
Old Mar 28, 2011 | 05:59 PM
oldford's Avatar
oldford
If no maf sensor is present, then the vehicle has a map-sensor.
Check vacuum hoses for leaks and cracks.
Exhaust completely leak free? Especially the first part where the oxygen sensor is.
If correct have the dealer read the codes and check the sensor values.
Old Mar 30, 2011 | 12:04 PM
martysmartie's Avatar
martysmartie
All petrol models have a MAF, Diesels have MAP, im sure it is located near the T/B, with a wiring connector coming from it?
Martin
Old Mar 30, 2011 | 01:55 PM
RichieST's Avatar
RichieST
Martin
The later black top zetec-se ones 100% don't have a MAF!
Old Mar 30, 2011 | 02:56 PM
martysmartie
It must have the tmap sensor inside the inlet then as described above I assume, never had to look, just going by what Haynes say!
Martin
Old Apr 3, 2011 | 01:21 PM
focus-rob's Avatar
focus-rob
thanks for all the replys. the problems i am having are when driving the car it will suddenly now and again start to hesitate and not acclerate as it should it feels like something is holding it back it revs fine but just want go anywhere and after a while it will go and the car will be ok again. i do have a eml light on and the codes are p0316 and p0141 but i cant find anywhere online to find out what the codes are .
Old Apr 3, 2011 | 04:06 PM
oldford's Avatar
oldford
No reply
Old Jan 31, 2013 | 11:25 PM
JCisJD's Avatar
JCisJD
i now have the same prob, did you get it fixed? was it the map as i replaced this and no joy but could not find a maf either. I have a mk1 1600
Old Feb 1, 2013 | 12:41 PM
martysmartie
The early ones as said have a MAF, the later ones have a 'TMAP' sensor, which is located in the inlet manifold.
A faulty VSS is known to cause hesitation as well...
Martin
15
Oct 7, 2015 03:43 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
Ben26
Sep 3, 2015 07:55 PM
Sep 3, 2015 10:49 AM
