Does anyone have a spare plate that the ARB mounts on to (passenger side)? My turbo just failed its MOT because the mounting plate is cracked. I'd prefer a new one rather than getting mine welded.
I also need a caliper clip as one of mine has come off! It's for the later style calipers that have bigger holes where the clip fits in to.
is it the clip bit at the front that pulls the caliper over?on the out side of the caliper?
It's the metal clip that goes on the side of the caliper, ie if you were looking straight through the wheel you'd see the side of the caliper and the clip attached to it.
Trip down the breakers, pull one off a mk4,quite a few mk4s about in the breakers
Ok I might have a look at the weekend - I thought only the better mk4 models had the arb tho? Might be difficult to find xr3's or RST's just in a scrappy?
The base models have front ARB's just not very thick ones, the ARB bushes may therefore be different too so dont chuck your old ones out just in case!
