saph steering rack 2wd and 4wd the same?
Old Feb 27, 2011 | 08:31 PM
chaffe's Avatar
chaffe
Turbocharging Technician
Default saph steering rack 2wd and 4wd the same?
looking into putting PAS on the saph, it is 2wd, i have been offered a rack from a 4x4, will it fit? and help would be great thanks
Old Feb 27, 2011 | 08:42 PM
jon@work's Avatar
jon@work
different
Old Feb 27, 2011 | 08:44 PM
chaffe's Avatar
chaffe
Originally Posted by jon@work
different
I know they are different, but will it fit? what are the differences?
Old Feb 27, 2011 | 08:45 PM
nicksaph's Avatar
nicksaph
totally different mate as said above.
mounting brackets are on different sides and i think the pinions are different lenghts
Old Feb 27, 2011 | 08:57 PM
chaffe's Avatar
chaffe
i could cut and weld the brackets, i wonder if there is something that could be done with the pinion shaft?
Old Feb 27, 2011 | 09:00 PM
nicksaph's Avatar
nicksaph
it might be as simple as fitting a 4x4 steering coloum uj instead of the 2wd one
Old Feb 27, 2011 | 09:03 PM
chaffe's Avatar
chaffe
it might be as simple as fitting a 4x4 steering coloum instead of the 2wd one
ill grab the column off the 4x4 as well than, thanks for the help. Not prepared to pay big money for a new rack when this one is £20 (plus it will be exchange, and i dont have a PAS one to exchange) just got an electric PAS pump and resevoir today.
Old Feb 27, 2011 | 09:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Nothing will fit so don't bother, the 4wd rack sits forward so the shafts are longer where it goes in.
Plenty of 2wd cars to choose from as they are all tAmesame, you can even fit one from a Granadab
Old Feb 27, 2011 | 09:35 PM
nicksaph's Avatar
nicksaph
i might be able to get you a xr4i power rack mate if your intrested. fitted to a car for a mot then the owner never go round to finishing the mot repairs so he broke the car.
so in all intents purposes it is never been used on the road. i can find out how much if your intrested
Old Feb 28, 2011 | 05:52 AM
chaffe's Avatar
chaffe
cheers, at least i know its a non starter now, thanks
chaffe's Avatar
chaffe
I appreciate the offer, but ill wait until i find something a bit more local if you dont mind, thanks
Rsmat
89
Oct 12, 2015 07:50 AM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
