2wd brake problem
Old Feb 25, 2011 | 03:56 PM
bruny's Avatar
bruny
Default 2wd brake problem
Hello guys.got a phone call today from Msd to tell me my car has developed a problem.the brakes are going soft and the pedal is going to the bottom and the abs pump is really hot.but after cooling down they go back to normal aparantly.and now the abs light stays on.any ideas what it could be and has any 1 experienced the same.also I don't hav a turbo shield on over the turbo .
Cheers lads
Old Feb 25, 2011 | 04:04 PM
Staffi's Avatar
Staffi
Surely Stu & Co can tell you what it is if they've called you about it??
Old Feb 25, 2011 | 04:14 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hi Fellas,
I expect when James spoke with you we had just come back from mapping as that was when we first lost the brakes, therefore he hadn't investigated any further than a look under the bonnet at the side of the road in the rain.
After further investigation, the ABS wiring is burning through as is the main harness down the drivers side chassis. This is wholly due to the fact your not running a turbocharger heatshield. However, as the car has been left to cool, James did mention earlier that braking effort has returned. Regardless, it needs serious further investigation.
I am sure James can fill you in properly tomorrow when he goes through your work report for you as he has gone home now.
Old Feb 25, 2011 | 04:30 PM
martysmartie's Avatar
martysmartie
Can't understand why you would remove it, it's also very dangerous due to it's close proximity to the master cylinder where the highly flammable brake fluid is!
Martin
Old Feb 25, 2011 | 04:33 PM
James @ M Developments.'s Avatar
Yo!
yes, when we got back from our final run the brakes had gone, and the ABS warning light was on,
After a little investigation, the wiring along the inner wing is burnt, the abs wheel sensor plug is burnt, the abs pump itself was red hot, and the wiring to it also very hot,
the reason the brakes went and the light came on was the fact the brake fluid in the resovoir was practically boilling, and the Power brake pump could not make pressure as the fluid was so thin and the pump was so hot,
the light comes on when pressure is low to tell you the brakes will not work when the accumulator runs out of pressure so you have a few brake applications left before they go completly,
As she cooled down and the fluid and pump came back to life, the brakes returned to normal,
So take careful note of page 3 of your work report, which will advise you on a few things you need to do before hard use, as she is very fast now, but not quite the complete package to abuse just yet.
The temporary heat sheild we use when cars turn up without them, simply wasnt good enough this time, as we had a motorway run, then straight into some traffic,
Old Feb 25, 2011 | 09:09 PM
bruny's Avatar
bruny
Ok mate thanks for that.I think the worst straight away.looks like more money to spend
Old Feb 25, 2011 | 09:58 PM
That's a cosworth for you lol
Old Feb 26, 2011 | 04:07 PM
Mike1's Avatar
Mike1
Sounds like it was caused by a missing part ( heat shield ) rather than the model of the car though? I guess SVE knew a little about these cars......
Old Feb 26, 2011 | 04:27 PM
bruny's Avatar
bruny
Your right mate.car is now at the local garage getting whole new discs and pads along with new fluid and getting a custom made shield as well.
Old Feb 26, 2011 | 05:54 PM
i was refering to the "more money to spend" comment
Old Feb 26, 2011 | 06:33 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you would be wise to flush it through with new brake fluid as if it's boiled, or has been close to boiling once, it will be more likely to do it again
Old Feb 26, 2011 | 07:53 PM
bruny's Avatar
bruny
Yes it's getting a full flush through out as our lass wants to drive it so want it safe
Old Feb 26, 2011 | 08:30 PM
Mike1's Avatar
Mike1
Good work - Castrol SRF and Motul RBF600 are good fluids
jason_nike
Aug 18, 2019 10:53 AM
FlashRS
13
Aug 31, 2015 06:02 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Old ford
Jul 31, 2015 06:50 AM
