ST170 kitcar issues.
Old Feb 21, 2011 | 07:25 PM
whitevanman's Avatar
whitevanman
Default ST170 kitcar issues.
Right, here's my problem. Im thinking of putting an ST170 lump in my MAC#1 kitcar, but I need some info before I buy the lump.
First off I want to run the standard management to help keep costs down, but I'm told I need to use the standard clocks, which is just not possible.Is there anyway around this or is this just not the case? The engine I'm looking at has: lump,ecu,transponder,loom,keys but no clocks.
Last of all is there anything that could cause a problem that I may not have thought about?
Cheers Gaz
Old Feb 21, 2011 | 07:48 PM
dingla rs's Avatar
dingla rs
just get a dash 2 mate round 5hundred quid tho
Old Feb 21, 2011 | 09:22 PM
whitevanman
I've got the dash sorted with a Koso unit. I just wanted to know if I needed the clocks to get the engine running on the standard ecu without the clocks.
Old Feb 21, 2011 | 09:41 PM
dingla rs's Avatar
dingla rs
yer you can
Old Feb 21, 2011 | 10:16 PM
cjwood555's Avatar
cjwood555
Engine will run without clocks - clocks just pick up the datastream on the SCP bus.
HTH
Chris
Old Feb 22, 2011 | 11:15 AM
whitevanman
Great stuff. I take it the datestream is a output from the ecu and requiers no inputs back from the clocks to the ecu, so just a simple case of blanking it off in the loom. you wouldnt have any drawing showing how this is done?
Cheers gaz
TPM961
Jan 15, 2018 10:50 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
talon1
Sep 15, 2015 10:27 AM
