What power?
T34.48 32psi
greys
standard head
Bd14 inlet cam
Standard compression
Wrc gasket
Long studded 200block
Grp A pump
What power roughly would this spec make?
If the housing was changed for .63 what difference would this make to power and drivability
Thanks Billy
greys
standard head
Bd14 inlet cam
Wrc gasket
Grp A pump
Thanks Billy
With the .63 power will come in with more of a punch later on, this is at the expense of LOST power lower down, 32psi, I'd seriously reconsider upping the turbo size for long life.
Although you cam make the power I'd seriously consider some porting, even having the exhausts ports cleaned up will bring the power in a lot lower and harder, and also help the top end, but not 100% essential.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
