250hp zetect turbo
I have built a 2.0 zetec turbo and put it in my mk4 1.3 bonus, what would I need to make around 250hp? It has a decomp plate, fiesta rs turbo inlet manifold and ofac ecu, escort rs turbo exhaust manifold and t3 turbo, thanks lee
i don't think you'll make it on a standard t3 from an rst, could be done on a cossie t3 though.
will need remapping and what injectors are you using?
i'm assuming the pistons are standard with using a decomp plate and as such i wouldn't want to push much through it.
but 15psi would probably get you there or very close, just get a bigger housing fitted e.g. 0.48 exhaust.
yea thats what i was getting at with the standard t3 bit, a cossy 2wd or 4wd t3 would be my recommendation to, with some greens, and you should easily see 250 me thinks. ask around a bit, fair few people with ZT's now.
Ok well ill pick up a cossy t3 then, at the moment I'm usind the standerd fiesta rs turbo injectors, what injectors would I need? And I didn't think the fiesta rs turbo ecu could be re mapped only a chip put in? Or am I wrong? Yeah I'm using standerd pistons for now
JK12
33
Apr 26, 2021 12:09 PM
