Show us your driveways
Afternoon ladies and gents,
I'm in need of some inspiration with my own driveway and wanted to see some good examples of well presented driveways. So that I can get an idea of lighting,plants,floor, colours etc.
Post them up
. I'll try and dig out a pict of my shabby drive
Thanks
Post them up
Thanks
My name has been changed for ages now just in case you didnt know fella lol. I will happily let you all me glenny boy if you like matey lol.
heres ours the day we moved in:
After the driveway:
And after new windows etc as well:
All done by me! and the polo has now been replaced with something a bit nicer as well:
After the driveway:
that lot including new fence all the way round the back garden and turf etc came to about Ł3000 materials only... cheapest quote i had for just the driveway without the fencing came to Ł5500...
Turbocharging Technician
was that at me? laying the pavings wasnt too bad, it was the hardcore and sand first that was hard work
Just a quick note! not sure on the details but I think you need planing now if you are going to block pave or concrete your front gardens, not needed if you are just replacing the existing drive and also not needed if you use the new type of paver's which have larger spacing gaps to aide with drainage, and also OK with gravel
I'm sure someone else in the know will give us the full details
our neighbours needing planning to do their driveway with paving, the bloke came round with measuring equipemtn to check for levels and stuff for drainage etc but didn't tell them not to tdrain it into my garden
yup thats right,
Needs to have a permeable surface or drainage for rain water.
So if you get your kerb dropped and drive is not following the above then its a no no to the drop kerb.
Since 2008 i think?
Since 2008 i think?
This was what it was like when we moved in
Ended up taking most of the wall down to get this out
This is what its like at the moment. Wanted to do it in indian stone but it would have cost twice as much. The retaining (sp) wall needs facing off in stone and some railings put round to finish it off
rsguy
44
Sep 29, 2015 03:29 PM
davidfox280585
Shows & Track Days
Sep 17, 2015 10:09 AM
