Ford Focus Ghia X?
Old Jan 31, 2011 | 06:42 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Ford Focus Ghia X?
I like to know if Ford produced a Ford Focus Ghia X version, modelyear 1998-2004?
And if so, did Ford also come with the Ghia X Estate version? And what kind of options did it have more as standard over the normal Ghia version?
Old Jan 31, 2011 | 08:04 AM
Bailes1992's Avatar
Bailes1992
Nope just a Ghia.
Pre Facelift had two different specs depending on the engine.
2.0's and SOME 1.8's had Rear leccy windows and a trip computer. Along with TC.
Most 1.8's, 1.6's and 1.8TDDi's were basically Zetecs with wooden trims
Post facelift all Ghias have Climate Control, rear leccy windows and a trip computer.
Old Jan 31, 2011 | 08:13 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Ok, thanks! So they were only sold in Germany where I bought my Ghia X.
Strange as normally Fords sold in the UK have more options as standard than the cars from Europe.
Old Feb 1, 2011 | 09:53 AM
Csm's Avatar
Csm
I have a ghia 1.8 tddi estate 2000 model
Full leather and rear leccy windows over the usual climate pack etc etc
No trip computer or cruise control though
Old Feb 1, 2011 | 01:42 PM
Bailes1992's Avatar
Bailes1992
The TDDi uses a Mechanical injector pump. Due to this I think it can't work out economy.
I think everything was an optional extra though
Old Feb 4, 2011 | 05:33 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Well my Ghia X has got an electric sunroof, cruise control and bi-xenon headlights. These items together are very rare on a Focus mk1. It has every option you can think of except no heated seats. And that option you find even in the lesser basic models..
Old Feb 5, 2011 | 05:16 PM
Colin_P's Avatar
Colin_P
The TDDI quite happily runs a fuel computer.
On my Ghia TDDI it was plug and plug, all the wiring was there.
Old Feb 5, 2011 | 08:32 PM
Csm's Avatar
Csm
Hence why i didnt bother my arse to reply
Old Feb 6, 2011 | 12:28 AM
Bailes1992's Avatar
Bailes1992
Really Now don't I feel like a tit
I know with the Pug's that use a Mechanical pump you can't fit a trip computer as it has no way or working out how much fuels been through it etc
Getting a TDDi Focus is looking more appealing every day. Shame about the crappy Lucas pumps though
Old Feb 6, 2011 | 11:24 AM
Colin_P's Avatar
Colin_P
They are not the old Lucas CAV rotodiesel pumps as used on the previous generation of Mondeos and Escorts. Saying that, I never ever had a problem when I had cars with that pump back in the day.
The Focus TDDI uses a Bosch VP pump which is fully electronically controlled. The said same pump that VAG used to use on their TDI's.
The fuel computer was plug and play on mine, all I needed to add was the stalk (indicator stalk with the button on the end to cycle through the fuel comp's functions) and an external temp sensor. I never bothered with the washer bottle sensor.
The only thing that is a bit squiffy on the TDDI is the range function. This is due to the TDDI having a 53 litre tank opposed to a 55 litre tank the petrols have. The MPG offset can be calibrated from the fuel comp and is very accurate once set up.
Old Feb 6, 2011 | 11:35 AM
Colin_P's Avatar
Colin_P
Hmmm.
I've read this a few times.
I cannot conlude what on earth your on about
All I can conclude is that it was posted at 9.32pm and that you were probably very very drunk at the time.
And I tell you what, if your arsehole can reply to forum threads, get down to the circus. You'll make a fortune.
There are always oportunities for arseholes with talent
Old Feb 6, 2011 | 11:48 AM
Colin_P's Avatar
Colin_P
More seriously though and don't offense from my japey reply above;
Did yours come with the x4 leccy windows ?
Mine has got only the fronts and upgrading to rears means a swapping out the front loom and adding a rear loom.
I'm interested if you did this and how you got on?
Also got heated leathers as well on mine which are very nice indeed.
Old Jun 20, 2011 | 08:20 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
I do own an original Ford Focus Ghia X. They were sold in Germany but very hard to find.
Old Jun 20, 2011 | 08:41 PM
Csm's Avatar
Csm
Nahh mines is 4 leccy windows from the factory fella
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
