Cosworth ecu l8 connecting with closed loop lounch,anti lag,wasted spark driver??
Old Jan 28, 2011 | 06:27 PM
Themistoklis's Avatar
Themistoklis
Default Cosworth ecu l8 connecting with closed loop lounch,anti lag,wasted spark driver??
Hello all,i bought one cosworth L8 ecu with closed loop,anti lag and lounch control system,and Wasted Spark Driver plus the wirring loom for 2 amplifiers but there is one brown plug and i don't know where is the plug in,so does anyone know the connecting for this plug and the connecting for anti lag and lounch control? any help really appreciated
hosting images
Regards Themistoklis
Old Jan 28, 2011 | 06:29 PM
botters's Avatar
botters
competant bodger
the big brown plug connects to your original amplifier plug mate
Old Jan 28, 2011 | 06:33 PM
cozzy jeff's Avatar
cozzy jeff
anti-lag and lauch control go to earth through a switch.
Old Jan 28, 2011 | 06:47 PM
Themistoklis
what need to do to my engine to work anti lag and lounch control separately,i mean i want one switch for anti lag and one another for lounch so does it feasible that?thanks a lot fo r any advice!!!
also what modification need to work these systems?
Regards
Old Jan 29, 2011 | 04:57 PM
Themistoklis
anyone?
Old Jan 30, 2011 | 07:31 PM
Stu @ M Developments's Avatar
PassionFords Creator
Send me the chipss Serial number to sales@motorsport-developments.co.uk and ask for the instructions to go with it mate and I will look after it personally.
Old Jan 30, 2011 | 07:46 PM
Themistoklis
Hello Stu. i already do that,and i would like all the instructions installation for this chip,lounch - antilag etc.if it's possible,thank you very much for reply.
Best Regards
Themistoklis
Old Jan 30, 2011 | 07:53 PM
bad boy rs's Avatar
bad boy rs
the 2 wires go into the ecu plug. i fitted my coil pack today and it was pin 21 & 26 but that was level 6
looks like stus on the case though
Old Feb 1, 2011 | 02:01 PM
Themistoklis
please help me . my car is in the garage. i waiting ..... thank's!
Old Feb 1, 2011 | 02:08 PM
I have already asked you to Email me which you havent done mate.
Old Feb 1, 2011 | 02:15 PM
Miller 3's Avatar
Miller 3
To activate the ALS and LC you need to earth out pins 13 and 14 (iirc)on the ecu multi plug
Old Feb 1, 2011 | 03:08 PM
Ok, got your email now and have replied, with attached instructions, but just in case my reply gets lost like your first mails, here you go:
Hi,
Thanks for your enquiry and purchasing one of our calibrations. The info we hold on file for that item are as follows:
Basic Calibration Specification for 3772:
Originally Sold: January 2008
ECU Type: L8 ECU
Babyboard Required: Yes
Encryption Key required: Yes.
Pectel or Weber: Weber.
Engine Type: Ford YB 2.0
Engine Compression: Standard
Head Spec: Standard
Camshaft Spec: Standard:
Injectors: Siemens 5lB
Turbocharger: T4
Map Sensor: 3 bar
Intercooler: RS500 type
Additional Features Installed:
Closed Loop active: Yes.
Air Injectors active: No.
Serial Data active: Yes.
Anti Lag active: Yes.
Launch Control active: Yes.
Flat Shift active: No.
Old Feb 1, 2011 | 03:11 PM
boost mad's Avatar
boost mad
Flat shift Stu ?
Old Feb 1, 2011 | 07:19 PM
Themistoklis
thank's all of you for the help.
Old Feb 6, 2011 | 07:06 AM
Originally Posted by boost mad
Flat shift Stu ?
Its a feature we developed to enable foot on the floor shifting for owners of dog boxes.
Old Feb 7, 2011 | 04:39 PM
Jim S's Avatar
Jim S
From: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
Flat shift Stu ?
And it works very nicely indeed, especially with my new box
Topjoe9
Aug 20, 2015 02:38 PM
Escortdriver1
Aug 19, 2015 09:02 PM
IAN RS2k
Aug 18, 2015 07:51 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Escortdriver1
Jul 31, 2015 02:36 PM
