cossie's a bit poorly
Old Jan 28, 2011 | 05:46 PM
5tox's Avatar
5tox
Question cossie's a bit poorly
the last few times ive started the car up it seemed to rev itself up every now and then until it was properly warmed up then it would be fine ...
So today i took out the Idle control valve and sprayed it with wd40 incase it was 'sticking'
Took the car for a 20 mile drive to dust off the cobwebs and again it revved itself up occasionally, the first 10 mins of driving the car were very rough.
Under normal driving the car would stutter as if it was running out of fuel but if you dropped it down a gear and thrashed it then it was fine
After 10 mins it seemed to pull itself together so finished the rest of the journey without any problems
I thought it was the ICV but now im stuck, any ideas?
Old Jan 28, 2011 | 07:29 PM
The raising of the revs shows the iscv to be working, as that is all it can do, ie admit extra air.
I would if not already done so recently change fuel filter, then check the co when hot and set the base idle speed, could just be a bit on the lean side, and with the cold weather this will affect it more when cold.
Old Jan 28, 2011 | 07:47 PM
JoeRS22's Avatar
JoeRS22
sound advice tab
Old Jan 29, 2011 | 08:10 AM
Fezman1's Avatar
Fezman1
I had this problem last year about this time...tried everything. It turned out to be abit of moisture/condensation down in the sparkplug holes. Pulled out the leads, spray of WD40, blast with the airline down in, dryed the ends of the leads and away she went. no fast idle. might be worth a try with the way the weather has been of late
Old Jan 29, 2011 | 08:47 AM
scotty4130's Avatar
scotty4130
Maybe worth changing the coolant temperature sensor?
jason_nike
Aug 31, 2015 10:15 PM
borboyous
Aug 22, 2015 11:17 AM
