Saff cossie ecu,s and wiring looms
Old Jan 26, 2011 | 06:32 PM
Default Saff cossie ecu,s and wiring looms
I was having a play about with my car at the weekend.Basicly the abs light was on and i was just checking connections on the abs ecu.I thought since i had the gove box out i would take the engine ecu out and have a look inside to see what chip was inside.
I disconnected the ecu and looked inside.I couldnt see a name on the chip.Anyway i plugged the engine ecu back in and the dam thing wouldnt start.I quickly checked and found the spark plugs werent firing and there was no power to the relay for the fuel pump.
To cut a long story short is it common for the wiring looms to nack up.Or do the ecu plug have to be fitted correctly.Im thinking i might have a brake in the wire somewhere cause i eventulay got the car running.
I had the ecu hagging out of its housing and it cut out again.I but the ecu back into its housing(where it sits) and the car started again.
Also does anyone have a diagram of the pins on the ecu so i know which wires are for which parts/sensors on the engine.
Thanks.
Old Jan 26, 2011 | 06:39 PM
Mike Kerbey's Avatar
Mike Kerbey
http://www.bigturbo.co.uk/
Click on the wiring tab and choose your ecu and you can buzz them all through with a multimeter to check continuity.
Old Jan 26, 2011 | 06:41 PM
Mike Kerbey
Also the abs light could be down to a dirty sensor.
You must remember that there wiring is going to be 20yrs old now and chances are its abit fragile so disturbing it could open a can of worms!
Old Jan 26, 2011 | 06:53 PM
martysmartie's Avatar
martysmartie
Not usually I have had mine out a few times, make sure the connector is firmly plugged into the ECU, and as said you can also test the wiring as well, the plug can only be fitted one way round.
Martin
Old Jan 26, 2011 | 07:19 PM
Ive sorted my abs fella.Thanks though.
Also what are the purple relays for.I know the 2 yellow ones are for engine ecu n fuel pump.The green one is for the abs.
I also noticed there was a black relay where these relays are.Whats the black one for.
Old Jan 26, 2011 | 07:37 PM
Wow that site is mint.Ive just had a quick look through and there is loads of info on it.
Thanks for that mate.
Old Jan 26, 2011 | 10:49 PM
jon@work's Avatar
jon@work
purple relays - ABS pump
black relay (and a grey timer relay which should also be there) - heated front screen
Old Jan 27, 2011 | 04:14 AM
I thought the abs was the green relay.
Old Jan 27, 2011 | 01:44 PM
jon@work's Avatar
jon@work
the green relay is for the ABS ECU
Old Jan 27, 2011 | 03:12 PM
sweet fella thanks for that.
Old Jan 27, 2011 | 05:55 PM
Im just lookin on bigturbo.co.uk. At the top where the fuel pump n ecu relays are. Is that the permanent 12v supply or is it 12v ignition supply?
Old Jan 27, 2011 | 09:51 PM
martysmartie
Both relays have a permanent and a switched feed to them, the latter is represented by the switch (Red bar facing upwards in that diagram) the ignition switch in this case, when you switch the ignition on the feed energises the relay hence tripping the "switch inside" hence power travels along to to the relay output and hence the rest of the circuit. So with a SPST relay you essentially have two circuits the relay itself (Live and earth) and the live output when the relay is tripped.
You will notice the ground connects to the ECU, this is how control of the fuel pump is obtained through switching the earth of the relay, the same applies to the ECU relay.
Martin
Old Jan 28, 2011 | 09:06 PM
Thanks for that info mate.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
s1turboman
Aug 29, 2015 04:27 PM
kosienutter
31
Aug 22, 2015 09:55 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
jdsjojo
Aug 1, 2015 08:50 PM
