HELP My 2wd saphire cos is running on 2 cyliders
Old Jan 26, 2011 | 03:31 PM
shlongie's Avatar
shlongie
Default HELP My 2wd saphire cos is running on 2 cyliders
Hi, can any one help me, ive recently put an engine in my saphire cosworth, and its only running on 2 cylinders (3+4). Ive checked for a spark on the 2 cylinders not firing, and they have a good spark, the injectors have their 12v feed, and seem to be working. ive gone round and unplugged 1 sensor at a time and they all make a difference to the running of the engine (its makes it cut out). Ive fitted new plugs (genuine ford), replaced the dizzy cap and rotor arm, plug leads are motorsport ones. Can any one make any segestions to what i can check next???
Cheers steve
Old Jan 26, 2011 | 04:59 PM
Fezman1's Avatar
Fezman1
phase semsor and its gap.
crank sensor and its gap and that all 4 lugs are intact.
might be worth doing a quick wee compression check too.
Old Jan 26, 2011 | 05:38 PM
martysmartie's Avatar
martysmartie
The fact they spark it quite good, so perhaps it's the injectors? The injectors are permanent live and switch earth via the ECU, the only real way to test this is with a NOID light, is the fuel getting to the two injectors?
Also as said check the crank pulley as the lugs can break off.
Martin
Old Jan 26, 2011 | 05:46 PM
JamesH's Avatar
JamesH
Take the plugs out of the cylinders that are not firing after you've just idled it, if the plugs are wet they're getting fuel too
Old Jan 27, 2011 | 08:12 AM
shlongie's Avatar
shlongie
Hi, ive done a compression test, all 4 cylinders on
are on 11bar. Ive just bored some noid lights this morning so ill be carry out that test at lunch.
cheers for all the replys
Carlbacciochi
24
Jun 30, 2016 04:31 PM
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
ray barker
Aug 7, 2015 09:00 AM
lockie
Jul 31, 2015 10:03 PM
