Focus Mk1 EML & Lambdas
Old Jan 25, 2011 | 07:15 AM
Mr cemex's Avatar
Mr cemex
Unhappy Focus Mk1 EML & Lambdas
Hi folks,
(im new here so be kind)
I just had the cat system changed after hearing some rattling noises inside the old cat at low revs. EML was still on when i picked it from StS garage.
So i took it to my local garage who told me that the front lambda sensor needs replacing as the "cables" were loose.
I reset the light via batery trick, but the lights came back on after 15 minutes. So i bought a new lambda and changed it myself to save labour cost.
Reset the light just in case but the EML came back on again after 15 minutes.
whats up doc?!
I might swap the old front lambda for the back one and see what happens.....
Old Jan 25, 2011 | 07:34 AM
martysmartie's Avatar
martysmartie
You need to have the fault codes read really as there must be another sensor which is outside it's limits illuminating the EML, if it's the Lambda then it may be the wiring to it. Strange it's only happened since the cat was changed.
Martin
Old Jan 25, 2011 | 10:39 AM
Bailes1992's Avatar
Bailes1992
Get a code reader on it. What engine is it?
Old Jan 26, 2011 | 06:34 AM
Mr cemex's Avatar
Mr cemex
Its a 1.6 Lx.
I will take it back to the garage and see what the reader says.
Can i swap the old front one for the rear one and see what happends ?
thanks for the replies folks,
Old Jan 26, 2011 | 06:50 AM
Bailes1992's Avatar
Bailes1992
Do you have 1 or 2 lambdas?
You may have pre and post cat or just pre cat.
Theres a Maf inside the inlet manifold, could be that too.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
RSMK4TURBO
Ford Focus RS
14
Sep 19, 2015 06:27 PM
JamboRS
28
Sep 14, 2015 09:02 PM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
