fiesta turbo engine (yet to be built) £500
Old Jan 23, 2011 | 08:38 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Default fiesta turbo engine (yet to be built) £500
as said realy ive been collecting bits ready to build a cvh turbo engine but my project has taken a tern for the.........best lol got a zetec turbo engine awaiting fitting lol.
well about the engine
1.4 cvh block over bored to Standard cvh turbo piston size + block decked
4 good fiesta turbo pistons
fiesta turbo crankshaft .25 grined on the mains and big ends
acl heavy duty big and main bairings standard thrust washers
burton power heavy duty oil pump
ARP rod bolts
new water pump
new timing belt kit
new piston rings
head rubuilt new cam (standard aftermarket)
new lifters
head skimmed
all valves re lapped and in good condition
full engine gasket kit!
sump modified to take an oil drain as the block hasent got one
engine yet to be built
pics can be taken if there is intrest
Old Jan 24, 2011 | 06:22 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I'm just about to rebuild mine, yet to see what nick the pistons are mind but dependant on condition I could be interested, if not would you split?
I'd need gasket set, oil pump, poss ARP rod bolts, piston rings
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
