tremec xr3r gearbox fit yb? difference from T5?
would a tremec xr3r box like this work with a Yb?
Is it a stronger box and is it geared different at all?
http://cgi.ebay.co.uk/Tremec-Gearbox...item4aa7c7b982
It wouldn't be impossible to get it to work, but would need a one off bell housing, or adaptor, as it secures different to the T5, there are a minimum of 380 versions of the T5, it's even used on the SANG YONG MUSSO for example!!
The ratio's would be very widely spaced in comparison to a cossie T5, which you can get alternate gear kits for anyway.
As a financial proposition it's a no go, rebuilt T5 a lot better, financially and gearing wise.
exactlly, I was wondering if there was a 6 speed varient which would be cool as fook to be honest, and different to every other road going useable saph, plus might not cost much as cossie t5's are getting expensive now days!
Matt i spose, does anyone know the ratios of a t5?
Example at 7200 rpm what speed would you be doing in 1st to 5th?
cheers
cheers
COSWORLD
Aug 14, 2015 07:40 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
