RST S2 engine bay resto UPDATE 09/06/05
well... I'm the kind of guy that dont let my RST out in the winter.... so I had to find something to spend my time on.. and when the car was restoret a few years ago, not much attention was payed to the engine bay... So now is the time... and then I thought to my self.. why not do the bumbers to.. just to ad a little change to the old girl....
I started the work bout a month ago.. but I dont work on it everyday... so I cant promise you daily update..
well.... I have pretty much space to carry out the work
this is how it loocked like when I started
first.. starting to remove all the easy bits... lights, cooler, rad, e.c.t
headertank, ECU, heater e.c.t removed.. still easy parts
turbo gone... hmm.. can anyone help me?? did I have a leaky exhaust manifold gasket
few more bits removed... engine almost ready to go out
dont worry... got it under control
suspension, brakes, driveshaft gone... and engine 15min from being out of the car
15mins later
more to follow
15mins later
more to follow
how it looked after the egnine were taken out
and after a few hours she looked like this....
the sparepart section
my pride... my stg 2 bernie box
next week I'll start to work on the bumbers..
damm.. you are right... and my steering wheel also.. AAARRRRHHHGG.. ooh no.. wait... its all yours that are in the wrong side
Its going to be really wierd, when me a CasperR, are going to the UK this summer for some shows..
DO YOU KNOW YOU DRIVE IN THE WRONG SIDE OF THE ROAD
Now I finally got started on my bumbers... cant wait to se them finished
still in pretty condition... its only 2 years since I had it painted
list removed
A bit enthusiastic perhaps
Bought my front bumber second hand and had it painted... but the bloke that fitted the splitter, had done a terrible job... so shortly after it was painted, it looked shite
so I had to grind it all down, and start from the beginning
Used a rather powerful tool to, "grind"
, the bumbers down, were the list had been..
will start to fill the bumbers in a couple of days... so... update will follow
list removed
Spend a few hours on my bumbers.... so now is taking shape
I spend bout 1KILO of fiberglass filler on these bumber.. and I aint done yet..
Some other bits I've been tidying up... more to come
Just picked this up the other day
Its a org t3, but with a 63 exhaust housing, uprated compresser housing, and modified blades for better flow, and 360 bearings..
Its a Trim 60 t3... so basicly its a Grp. A. turbo
The modified compresser housing
What a difference
What a difference
Finally I pulled my finger out and took some pictures
enjoy
I thought I had a pretty good condition S2, BUT, when you take it apart, you find all the thing that have been hiding, but still.. It could be worse
new batteri tray welded in
Ready to go to the paintshop
My helpful dad... tanx
This is for me the turning point... GOT IT PAINTET.. now all there is left, is to put it all back together
WELL.. I havent got around to post some pictures for a while... but here are some.. this is were I am at now...
My alternator were looking pretty bad..
So I took it apart, and sandblasted the housing and painted the other thing.. and it came out looking like this
Just before I put the car away for the winter, my alternator (due to bad engine/gearbos mounts) cut a hole in my buttom waterhose
but luckely, one of my freinds had a solution to that problem
hi adam..
I had the whole car painted for a couple of years ago.. so it was only the engine bay this time, but the painter sprayed the front very quick, just to give is some colour
Im actually very pleased with that ECU
even thoug it was fookin expencive.. LOOL
just kiddin mate
well... tha car i almost finished now.. I still havent finished my bumbers... but will post som pictures when the are done...
first some picture of my starter heatsheild... didn't know the thing existed
THANKS CasperR
here are some picture of the state the car is in now... enjoy
one of the things that need to be done, is to make the boosthoses in stainlees steel.. and then have them polished
THANKS CasperR
track.focus'd
Aug 12, 2015 05:53 PM
