who uses one of these
Old Jan 20, 2011 | 01:04 PM
t16coupe's Avatar
t16coupe
Default who uses one of these
heard about 1 or 2 cars being stolen in my aera so brought one of these
Old Jan 20, 2011 | 01:11 PM
cozzy jeff's Avatar
cozzy jeff
alot of people use these but there is a modification you need to do to it to prevent it being peeled off
Old Jan 20, 2011 | 01:20 PM
t16coupe's Avatar
t16coupe
i do also have a clifford concept 950 and tracker i did also only pay Ł15 for the disklok so cheap bargin i thought
Old Jan 20, 2011 | 01:23 PM
Rax's Avatar
Rax
They have been around for years,I have two of them I use.The first generation was a padlock locking one and since then different key varieties.As said though they can be peeled off by the rivet I think but you can mod them by putting a plate on the back.If anyone has pics could you post them up please.I just attacked mine with a welder and welded any gaps up
Old Jan 20, 2011 | 01:24 PM
Fil's Avatar
Fil
ELASTIC BAND
have had one for many years, but they need to be modded a bit , as they have a few very week spots, google will reveal all, probably youtube these days aswell.
Old Jan 20, 2011 | 01:50 PM
COLEYST200's Avatar
COLEYST200
Iv hade one on my 3dr for 2 years now
Old Jan 20, 2011 | 02:11 PM
cozzy jeff's Avatar
cozzy jeff
i had to cut one off,went to scotland for the weekend parked the car in a car park and put the lock on,after the weekend went to remove the lock and realized i had left the key in the house,took me 45minutes to remove with only a screwdriver and an 1/2 inch ratchet as a hammer.
Old Jan 20, 2011 | 04:35 PM
xr4x4rs's Avatar
xr4x4rs
and a lot of noise i bet. still 45 mins to do it, you know its doing its job
Old Jan 20, 2011 | 05:04 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I've got one for my rs turbo, keep meaning to modify it. 2 plates over the hinge pin and 2 steel strips down the back either side so it can't be prised off, also wanted to fit a padlock to the bar that swings down to lock it, easily done with a welder so why nae??
Old Jan 20, 2011 | 05:09 PM
stu21t's Avatar
stu21t
do u think if some1 gets passed the lock, alarm, immobiliser.....
the disc lock will stop them?
Old Jan 20, 2011 | 05:12 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
ive got 1 bought it when u new i was getting a cosy then i got1 with car so ended up with 2 lol
Old Jan 20, 2011 | 05:42 PM
Fil's Avatar
Fil
ELASTIC BAND
no, but I do think if there are two cars the same in a car park, one with a diskloc and one without, you've got a better chance your car will still be there and un touched
Old Jan 20, 2011 | 05:51 PM
Chaz888's Avatar
Chaz888
very good point I work in securty and the best thing to stop theft is layers of security all can be broken for sure but the time and skill it takes to crack each level is what puts most off.
Old Jan 20, 2011 | 05:58 PM
martysmartie's Avatar
martysmartie
As said it acts as a detterent if nothing else.
Martin
Old Jan 20, 2011 | 05:59 PM
cozzy jeff's Avatar
cozzy jeff
yeah alot of noise and alot of funny looks from people using the car park,but the thing is not one of them phoned the police to check to see if the car was being stolen.
Old Jan 20, 2011 | 06:09 PM
Rax's Avatar
Rax
The more security they have to bypass the harder to steal.The ammount of cars that used to go missing without a disklok being fiited was quite high years ago regardless of an alarm being fitted .Bonnet vents/front grills ripped out and disconnecting the pin switch or the alarm.Every little helps imo.
Thats how I see it,ok thay are not truly infallible but its 100% better than nothing.Even if its used more as a visual detterent,worth having one
Old Jan 20, 2011 | 06:16 PM
Rax's Avatar
Rax
I remember you posting this before.If this happened anywhere near to where I live some scally would of offered you a hand getting it off without even asking if it was your own car
Old Jan 20, 2011 | 06:24 PM
botters's Avatar
botters
competant bodger
there was a program on years ago about car theft deterrents the above was one of them the ex car thief they got in to do the demonstrations got in the car removed the disklock and started the car in summat daft like 54 seconds armed with just a flathead screwdriver
Old Jan 20, 2011 | 06:27 PM
Can be removed in less than 5 seconds SILENTLY with the correct tool, but any deterrant is good, 100% better than nothing.
Old Jan 20, 2011 | 06:37 PM
Chaz888's Avatar
Chaz888
Is thare still a system were you can un-clip the stearing wheel ? like a F1 car ? allway though it was a neet solution thou carring round your wheel is a bit naff.
Old Jan 20, 2011 | 06:45 PM
RSGeorge's Avatar
RSGeorge
Snap off boss for the steering wheel you mean?
they are still about http://www.motorspeed.com/store_main...roduct_id=2001
Old Jan 20, 2011 | 07:20 PM
St3V3_C's Avatar
St3V3_C
No tabs, we are not talking about the key...
I have one too.
