Vacuum lines question
Old Mar 29, 2004 | 02:52 PM
Default Vacuum lines question
I have a 1995 LHD Escort Cosworth and I'm trying to figure out a second vacuum line. The vacuum line for the boost gauge is split and there are two lines that pass through the firewall. One enters the cabin just above clutch pedal pivot. The second vacuum line goes through the firewall by the brake master cylinder (lhd). One of these is for the boost gauge but what is the other vacuum line for?
Old Mar 29, 2004 | 03:06 PM
Dave Henshall's Avatar
Dave Henshall
it may be for a secondary boost gauge - has it had one fitted on the a pillar or in the dash previously..?
Old Mar 29, 2004 | 03:27 PM
Just the boost gauge in the center pod. I don't know if there was a different one fitted before I got the car.
Old Mar 29, 2004 | 04:08 PM
Dave Henshall
is it p8 or eeciv controlled - i know the p8 ecu does not have any other pressure/cac lines going through the bulkhead.
Old Mar 30, 2004 | 04:48 PM
The car originally had the EECIV (small turbo car) but was upgraded to P8 and a T35 turbo. Now currently runs a Autronic ECU
Old Mar 30, 2004 | 06:52 PM
Dave Henshall
could be for the MAP sensor if it has been mouted inside the car then ...
Old Mar 30, 2004 | 07:43 PM
THE RADMAN's Avatar
THE RADMAN
does/did it have aircon? as there is a vacuum line for this,connects to a valve under the scuttle,near the wiper motor, nick
Old Mar 31, 2004 | 04:33 AM
There is a separate line for the MAP sensor - which now goes to the Autronic ECU. It does have aircon. What is the scuttle - we must have a different name for it here in the USA Thanks RADMAN - that is the info I was looking for!
Old Apr 1, 2004 | 10:26 AM
whitneyd's Avatar
whitneyd
It's the vents at the back of the hood where the wiper motor and blower box is at.
Old Apr 9, 2004 | 11:26 PM
Big Andy W's Avatar
Big Andy W
yes Its for the cabin recirculate actuator next to the heater box!
Old Apr 10, 2004 | 03:34 AM
learn some thing new every day on here it's all good
chowfornow
14
Jan 5, 2019 09:01 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
muzzman1
Sep 30, 2015 08:59 PM
hopper350
Sep 4, 2015 12:53 AM
