Connecting megasquirt to laptop?
Can this be done with newer laptops as my ms ecu has a db9 serial port? i cant be bothered going away to buy an old shitty laptop to hook up to my car when i have a laptop here that might be capable of the job! is there a certain conversion wire i can buy? cheers in advance
Turbocharging Technician
Yeah they talk via usb serial addapters i downloaded drivers through windows 7. When you download the software from diy autotune you get a port checker and it tells you what ports are open. You then go to mega tune communications and select the port which the port checker has said is open.
Hope this helps.
Hope this helps.
my vagcom lead is basically a serial to usb adapter, and that works well enough.
not that thats much help
personally i would buy an adapter and have a play, cant see it being too much of a problem if you know your way around a PC?
PCMCIA one on the other hand, you just plug it in and it works straight away no problem at all and no fuss.
Feck knows why no one is listening to me TBH, because Ive been through this so many times before and learnt the hard way and am just trying to stop you guys having the same issues.
PCMCIA = WIN EVERY TIME
USB = IF YOU ARE LUCKY
which is why i said 'personally'
i have only ever connected to one type of ecu and that was using vagcom and had no issues. Just offering an opinion.
oh and
well its currently a salt plant including boreholes for gas storage, fluidised bed driers, evaporators, Gas/Oil Fired boilers and CHP plant.
oh and
writing software at all levels from controlling power stations
If you do want USB to Serial then this one works fine for me running W7 http://cgi.ebay.co.uk/USB-2-0-RS232-Serial-DB9-9-Pin-Male-Adapter-Cable-PC-/250653067355?pt=UK_Computing_CablesConnectors_RL&h ash=item3a5c16485b
I use a Netbook for mapping (much less bulky than a full size laptop) and it doesnt have a PCMCIA slot.
yes they will work but its a job to find the right adapter to work think i went through 3 before getting it right lol
also if your running ms1 why dont you upgrade to ms2 far better mapping program and its cheap and easy to do think i paid 50 quid for my chip,and then its just a case of unplug the old chip and push in the new chip and the download the new software
realy easy,it will make mapping a whole lot easyer for you,
great bit of kit wish i had'nt sold mine lol.
also if you have any problems have a word with dale at baileyperformace.com in telford i highly recomend him realy knows what he's doing with the m/s ecu's
once again i need to agree 100% with chip and foreignRS.
i will agree that in some scenarios they will work, but also in some scenarios they will appear to work, they go horrible wrong in the middle of downloading a map, corrupting the map and leaving you calling the AA.
chip, do you remember when we were doing my saff and with the USB dongle and it corrupted it whist we were driving?!?!
PCMCIA serial adapters use HARDWARE to process the signals.
99% of USB ones use SOFTWARE to process the signals via a device driver.
also the new PCMCIA replacement, Exprescard ones again use USB (they are a usb devic e with an exprescard interface) so these are not the same as hardware/PCMCIA ones!
The problem with nearly all of USB to serial converters or problems with them falls into 2 catagories...
1) They cant acheive non standard baud rates (Such as the L8 IAW programs use)
2) The program software you want to use doesnt use the windows system correctly to make use of the converters.
I.E. The programmers of the software you want to use take short cuts to save time which leads to these kind of non working problems.
Any software I write using comms routines have never had issues with any USB-serial converters except for when Item 1 above is beyond the programmers control.
I have found a brand of USB-Serial lead that has never failed to work on anything I have tried although I have never tried it on Megaquirt as the name just makes me shivver
Here is the link...
http://apple.clickandbuild.com/cnb/s...+RS232+%2B+DB9
About twice the price of others but it is quality...
Here is the link...
its already mapped and running, (was on this engine before) just needs a few tweaks, increase boost cut and map the boost/transition as its now running a smaller turbo with slightly more boost
Mark RS
Oct 12, 2015 06:01 AM
