mk6 escort question
my wife has a gti escort and as of late the passenger side only foot well seems to have a bit of water in it
not loads but if you push down on the carpet its quite wet
im thinking heater matrix as the water level in the header tanks seems to drop a bit
is the matrix located on that side behind the dash
and
is it a pain in the ares to remove the dash and replace the matrix
there is no holes in the floor and door rubbers are mint
what you thinking ???????????????????
and
Don't know if this could help but on some car the pipe for the rear washer runs underneath the carpet and in winter the jetts freeze up and the pipe can pop off had this happen to a car of mine a few years back and caused the carpet to get wet.
robably a long shot but thought i would mention it.
battery tray is mint
window rubber is mint
but could be the rear washer as it only had water in the bottle over winter and it froze solid
will take the seat out and see
will also pour water over the car on that side
thanks for the help guys
