focus Speedo Clocks
Old Jan 15, 2011 | 07:28 PM
Magnum PI's Avatar
Magnum PI
Default focus Speedo Clocks
Hi folks,
My Mates wife as a v Reg, MK1 1.4CL Focus that has developed the old 'speedo needle stops working' syndrome.
I've offered (if they can source a replacement speedo cliock unit) to change it for her.
she drove home today from work and the speedo didn't work at all. at other times it stops working intermittently.
Question is, if I swap the clocks, will the replacement speedo clocks show the correct mileage once connected?.
Is the mileage data stored on the speedo clock unit, or elsewhere?
Andy
Old Jan 15, 2011 | 08:00 PM
danme1987's Avatar
danme1987
no the milage is stored in the clocks so will need a trip to ford. also ive heard something about this being the speed sensor not the clocks
Old Jan 16, 2011 | 12:35 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Its nothing to do with the speedo. Its a speed sensor in the gear box & a cheap repair at Fords.
Well, im sure mine went the same as yours but it was about 5 years ago.
Old Jan 16, 2011 | 12:57 PM
RichieST's Avatar
RichieST
As above it is most likely the speed senor in the gearbox, and they can be a total fucker to get out if siezed in!
Old Jan 16, 2011 | 02:22 PM
martysmartie's Avatar
martysmartie
Most likely the above, to confirm go around 10MPH and drop into neutral AND release the clutch, revs should raise to around 1400RPM. Mileage I am sure is stored in ECU.
Martin
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Bransby
Sep 14, 2015 08:54 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
