Stud's
Just use 2 nuts on the same stud, lock them together by turning them against each other, then drive it in using the top one. Be careful putting the studs in, they only go to a very small torque, about 4nm I seem to remember, so basically just nipped. Once in, just loosen the nuts off and away you go
I have been replacing my engine mounts and wanted some titanium nuts to hold them in as on the fiesta RST the covered with shit from the road so after 19 years needed lots of encoragement to come off I orgered some today and the were posted this afternoon! the place I got them from this time was:
http://www.discovolantemoto.co.uk/ti...al/cat_13.html
they are a Motorbike outlet one man band and give very good service.
Hope this helps. private message me an email address and I will send you some pics if you want
