healight issue's please help mot failure
Old Jan 11, 2011 | 08:50 AM
shepherd-racing's Avatar
shepherd-racing
Default healight issue's please help mot failure
hey everyone , i need a few quick answers to my prob , i have a mk3 fiesta base and as far as im aware the loom is un modified , it failed mot on a head light issue i.e when in first turn of the stalk side lights and "dipped" beam come on ,im told this is incorrect the rest of the light funtions fine and tbh ive never realy thought dipped being an issue
any answers please car is a 96 p reg if that makes any odds
cheers
Old Jan 11, 2011 | 09:03 AM
phil_focus's Avatar
phil_focus
sounds like a wire fault in the past with the dipped beam so somenes wired the dip to the side lights.
Old Jan 11, 2011 | 11:15 AM
Does it have dim dip ?, in which case the headlight dip will come on at around 1/2 brightness if the ignition is turned on when the sidelights are selected, and is 100% CORRECT TO DO SO, and NOT a MOT failure.
If however the ignition is not on position 2(running) and the dips are on on sidelight setting that is wrong.
Old Jan 16, 2011 | 02:23 PM
shepherd-racing
thanks alot , ima check this out , how would i go about fixing it ?
Old Jan 16, 2011 | 02:30 PM
shepherd-racing
ok so with ignition off only sidelight are on sidelight option , my stalk only has two clicks on the first my sidelight and 1/2 light main come on on second main beem full and for flash push stalk forward , is this right? i know ive asked but im still abit dumb on the subject lol
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
