PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Technical help Q & A (https://passionford.com/forum/technical-help-q-and-a-14/)
-   -   healight issue's please help mot failure (https://passionford.com/forum/technical-help-q-and-a/379838-healight-issues-please-help-mot-failure.html)
shepherd-racing Jan 11, 2011 08:50 AM
hey everyone , i need a few quick answers to my prob , i have a mk3 fiesta base and as far as im aware the loom is un modified , it failed mot on a head light issue i.e when in first turn of the stalk side lights and "dipped" beam come on ,im told this is incorrect the rest of the light funtions fine and tbh ive never realy thought dipped being an issue
any answers please car is a 96 p reg if that makes any odds
cheers
phil_focus Jan 11, 2011 09:03 AM
sounds like a wire fault in the past with the dipped beam so somenes wired the dip to the side lights.
tabetha Jan 11, 2011 11:15 AM
Does it have dim dip ?, in which case the headlight dip will come on at around 1/2 brightness if the ignition is turned on when the sidelights are selected, and is 100% CORRECT TO DO SO, and NOT a MOT failure.
If however the ignition is not on position 2(running) and the dips are on on sidelight setting that is wrong.
shepherd-racing Jan 16, 2011 02:23 PM
thanks alot , ima check this out , how would i go about fixing it ?
shepherd-racing Jan 16, 2011 02:30 PM
ok so with ignition off only sidelight are on sidelight option , my stalk only has two clicks on the first my sidelight and 1/2 light main come on on second main beem full and for flash push stalk forward , is this right? i know ive asked but im still abit dumb on the subject lol
© 2026 MH Sub I, LLC dba Internet Brands
