Breather Set-up Question
Old Jan 9, 2011 | 04:59 PM
bromley's Avatar
bromley
Default Breather Set-up Question
I'm just about to plumb in my breather and cut all the hose to length etc and Just just want to sanity check the way i intend to set it all up.
I've breather fittings on the engine in the following places:
cam cover
original kidney box
one returning to one of the wings on my big wing sump
one in the block on the exhaust side.
I've a breather with 4 -10 fittings i intend to connect as follows:
cam cover breather and one on the block (exhaust side) connected via a Y piece into the top of the breather.
Kidney box also connected direct to the breather top.
One on the base of the breather as a return to the sump.
One on the base of the breather as a drain, probably run into a chassis leg under car.
Really i want to know if this sounds ok to people, or hear any other ways i should be doing it.
Thanks in advance.
Old Jan 9, 2011 | 06:44 PM
AndyPen's Avatar
AndyPen
Sounds like its correct. The only thing I was wondering is the capacity of the breather as you are running the extra pipe in via a Y piece?
Old Jan 9, 2011 | 07:26 PM
bromley's Avatar
bromley
Thanks for the reply, much appreciated.
The breathers probably not ideal size wise, but it'll do to get the car up and running again.
I did ask someone to weld a fifth port to it while they were welding the dash fittings on but they've forgotten hence why i was going to use a T for now, although i might just take it to work tomorrow and get someone to weld another fitting on tho.
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
