t5 oil
Old Jan 9, 2011 | 09:07 AM
D16PJM's Avatar
D16PJM
Default t5 oil
What oil do you use in your gearbox and how much as I need to do the rear seal on mine so will change the oil.
Thanks Pete
Old Jan 9, 2011 | 11:22 AM
LHD220Turbo's Avatar
LHD220Turbo
ford recommend ATF fluid, dexron 2 i believe
but some use 75w/90 gear oil.
the only issue with using gear oil, is when the oil is cold, it will be notchy and sometimes difficult to get into gear.
you'll need between 2.5 and 2.7 litres, depends on how much of the old fluid you get out
Old Jan 9, 2011 | 03:57 PM
The atf type oil that ford recommended is NOT std atf, it was a particular atf, that was engineered specifically for the T5 version in the cossie(there are 380+ versions).
The nearest is CASTROL TQ-D, it wasn't helped by ford/BW changing some box parts materials during manufacture, halfords sell the TQ-D, about Ł10 a litre.
No dexron has ever been specified, although dexron 2E is close, it is much closer to a mercon oil.
Old Jan 9, 2011 | 05:47 PM
Thanasis's Avatar
Thanasis
TORCO 75w/90 100% synthetic all the time
Old Jan 9, 2011 | 09:01 PM
jaimesdna's Avatar
jaimesdna
mine has normal atf in it. its a bit notchy in the mornings when its -10 outside but fine in normal weather
Old Jan 9, 2011 | 09:38 PM
jamie's's Avatar
jamie's
mine has standard atf in it with no probs
its always been a little notchy when cold, even when i 1st got it
had the oil changed twice now and ever made any differance
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
