Con Rod YB question...especially for Karl......
Old Jan 31, 2005 | 03:58 PM
ImaRacing 700's Avatar
ImaRacing 700
Default Con Rod YB question...especially for Karl......
....I would love your serious input here.
What causes a std YB conrod to break?Would 700bhp at a rev limit of 8000rpm just break it thru sheer power?.....As i noticed the arrow ones are rated to 10000rpm,does that mean i dont need em?...Plus how much stronger does shot peening give over a std unit?
I have had Marks advice and if i went his way it wouldnt be my own design
Old Jan 31, 2005 | 04:01 PM
TIFF's Avatar
TIFF
Chasing Radders
Phil
Do you REALLY think that Karl should reply to you, after the crap that you give him
Very strange man
Old Jan 31, 2005 | 04:04 PM
ImaRacing 700
Its up to Karl...he seemed to respond to my ECU question
If he dont i wont loose any sleep
I thought Karl knew its all banter...thats what was said over the phone anyhow..if he takes it seriously thats up to him
Old Jan 31, 2005 | 04:14 PM
Get some decent rods mate, if you start to get Det for any reason then the last thing you want is to be on rods that are only just good enough.
Plus they are pure porn to look at, heres mine for my mini:
Old Jan 31, 2005 | 04:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Like Chip said, its det thats gonna be the main killer. At that power, the smallest det and blammo, dead rod, the in cyl pressure when detting is like, 10times more than under normal running IIRC.
Be interesting to try, but if your spending serious money, is it worth the risk as if a rod goes itl take the rest with it!
Old Jan 31, 2005 | 04:45 PM
RANJ's Avatar
RANJ
phil
do things propper
Old Jan 31, 2005 | 04:51 PM
Almost identical to my mini ones, lol
Old Jan 31, 2005 | 04:54 PM
ImaRacing 700
Ranj...this is my spec...no frills....its got to acheive ONE goal..thats it then purely road car which will never see out of second gear which means about 0.5psi I will be nagging Mark with specs soon to see wether he thinks i am MAD
Old Jan 31, 2005 | 04:59 PM
To get 700bhp you are going to need low compression and a big turbo realistically, its not going to make a very nice road car like that, you would be better off selling the complete built engine and putting a stage 3 one in.
Old Jan 31, 2005 | 05:05 PM
ImaRacing 700
low compression realistically
Utter horse shit On any speed run it will run very high octane fuel!...IF i choose to go highish compression....Thats the problem i have had 7-1 on T4 8 greens and it was a bitch to pull out of junctions unless i put anti lag on...but there was a fear of setting light to the car behind..ROFL
Old Jan 31, 2005 | 05:11 PM
Phil, i thought you were going to be running on road fuel and no nitrous.
You are correct that if you use a boatload of toluene and/or nitrous or similar then you can get away with higher CR.
Old Jan 31, 2005 | 05:47 PM
ImaRacing 700
Yes but it wont be mapped for it...just std map as it would be cheating using a race fuel map
stevecfrst1
Sep 30, 2015 05:18 AM
little bram
Sep 27, 2015 07:45 AM
S3an
Sep 26, 2015 11:39 PM
coscor86
Sep 20, 2015 01:21 PM
S3an
13
Sep 13, 2015 10:01 AM
