mk5 fiesta o/s drive shaft removal
Old Jan 2, 2011 | 02:15 PM
nm_coolj's Avatar
nm_coolj
Default mk5 fiesta o/s drive shaft removal
Hi just trying to remove the o/s drive shaft on an mk5 fiesta. Iv just managed to remove it from the hub now im just stuck trying to pry it out.
It looks like its held in by a bracket at the inner joint with two bolts.
Has anyone done this.
do i need to remove the bolts or does it just pull out.
any help would be appreciated.
Old Jan 2, 2011 | 02:26 PM
bythomson's Avatar
bythomson
yeah youll need to unbolt the bracket thing the in will just pop out
Old Jan 2, 2011 | 03:53 PM
nm_coolj's Avatar
nm_coolj
nice 1. thanks ill give it a pop tomorrow
Old Jan 8, 2011 | 01:32 PM
nm_coolj's Avatar
nm_coolj
Default back again
o/s drive shaft done now doing the near side. Same problem again i cant seem to get it to budge with a large screwdriver. this time there is no bracket holding it. Any ideas???
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
