radiator and piping questions
Atm i putting a 2.0 blacktop zetec into my mk5 fiesta. Am i right in thinking ill be best using a rad out of a focus and then using the focus pipe work to connect it all up?
As i no the 1.4/1.6 focus also share the same se engine out of the mk4/5 fiesta as well.
Would this work or am i best using custom pipe work
cheers guys
cheers guys
Having never actually done the conversion I'm maybe not the best guy to ask but personally I'd use the pipework from the focus thus keeping the cooling level correct.the rads on a focus aren't that big anyway so you should be fine.
chowfornow
14
Jan 5, 2019 09:01 PM
