removing spot welds
Old Dec 27, 2010 | 11:00 PM
andy130's Avatar
andy130
Default removing spot welds
i bought a wurth bit for it an tbh its fucked after doing both sills one 1/4 panel what best cutter out there got £30 to spend?
Old Dec 27, 2010 | 11:03 PM
botters's Avatar
botters
competant bodger
i use machine marts £7 quid cutter it cuts around the spotweld on one side of the panel only they last for ages so long as they are used SLOWLY! ive had the same one for over a year and it has removed numerous panels
Old Dec 27, 2010 | 11:29 PM
andy130's Avatar
andy130
is that the one that looks like a nomal bit botters?
Old Dec 27, 2010 | 11:57 PM
vaughant's Avatar
vaughant
Nah,machine mart ones have the springloaded plunger and like a mini hole cutter around the outside.
Otherwise try a cobalt spotweld drill but as said above slowly and perhaps some sort of coolant/rtd spray.
Ive used both and found the machine mart version far more effective.
Old Dec 28, 2010 | 12:01 AM
rst in breaking's Avatar
rst in breaking
i had a machine mart one when i done my old fez rear quarter and found it crap tbh, mate who works in vw bodyshop gave me one which looks like a normal drill bit but flat at the end with the point in the middle sticking out about the thickness of a skin of metal if that makes sense, great bit
Old Dec 28, 2010 | 12:09 AM
botters's Avatar
botters
competant bodger
thats the one works wonders for me
Old Dec 28, 2010 | 12:11 AM
botters's Avatar
botters
competant bodger
yeah ive used those very easy to end up going through both panels tho if not carefull which could potentially fuck a job up if you cant get to the other side to weld
Old Jan 3, 2011 | 08:40 PM
sikora's Avatar
sikora
What's the most common size bit to use?
Old Jan 3, 2011 | 09:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
all the ones i've used have looked like this
Old Jan 3, 2011 | 10:07 PM
dingla rs's Avatar
dingla rs
the one above is shit get the one with spring loaded plunger like a minin hole cutter i got a set ,removed 4 quarters sills ,removed loadsa parts on 3 car builds and im still on the first bit go slow and they last ages best iv found
Old Jan 4, 2011 | 12:01 PM
Twellsie's Avatar
Twellsie
a treppanning or butterfly drill, I always used to grind my own from normal drills, the depth of the recess between cutting points and centre wants to be 3x the thickness of the metal otherwise they burn out dead quick
nico12
Dec 31, 2015 04:42 PM
cossie330
Oct 7, 2015 08:22 PM
Fudgey
Sep 17, 2015 01:06 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
hopper350
Sep 4, 2015 12:53 AM
