Burning oil, MOT failure?
For my next mondeo question! lol
Im looking at upgrading my runabout once ive repaired the wheel bearing, there is a dirt cheap 53 reg mk3 mondeo for sale near me, 1800 zetec petrol, but its burning oil, not much just has to be topped up once every few weeks,it runs and drives mint, just a little smokey on startup, and the mechanic friend of the guy who owns it has told him it will fail the MOT on emissions because of the oil burning? Is this correct? as the guy who owns it isnt using it and is selling it for spares/repairs/scrap money basically, as im kind of interested in buying it as its at a bargain price, just has no MOT or tax, and uses oil, its immaculate otherwise. Ta
AS said depends. My fiesta was burning oil (at a rediculous rate, did over 2.5 litres in less than 160 miles), used to be able to se it burning when you booted it. Yet, it passed a mot like it...
I think you have basically answered your own question. As the mechanic has already said, if the burning oil falls foul of the emission test then it will fail the MOT.
Maybe worth taking a gamble on if it's dirt cheap though.
Ive found with cars that burn oil that the oil being burnt tends to kill the cat. We had a pug 106 in that had not been serviced in years and had started burning oil because of this. It failed its mot due to the cat not working but there was no signs of smoke being immited from the exaust so we changed the cat and gave it an oil and filter change (using slitly thicker oil) and it passed no problems
probaly need another cat next year tho lolol
If the smoke is visible it should fail.
But considering the last two vehicles Ive bought from England, which had brand new MOT's. It seems absolutely anything would pass an MOT over there.
One vehicle had broken headlight and knackered rear shocks.
The other the horn didnt work and they seem to think removing the ABS bulb fixes the problem.
Dodgy as fuck !!!
Dodgy as fuck !!!
If it does pass on the measured emissions then it is up to the testers discretion to pass/fail on excess visual smoke.
Find a garage that sells Forte engine treatments. They work wonders on this kind of problem. Some of the problems this stuff can cure if pretty damn impressive.
http://www.forteuk.co.uk/index.php
I went and had a proper look at it earlier, its a little sluggish starting, and doesnt smoke really on tickover, then when you give it a good rev you get the smoke, and it stinks, and it makes this chugging sound out the exhaust on tickover, and if you take the oil cap off while its running it makes a right racket chugging away, bottom end pressure. not sure if its worth the gamble or not.i like buying cheap cars to repair for profit but not sure if this ones going to go my way, ive offered him £300 for it, id get that back in bits, but MOT and 6 months tax is going to be another £150 ish and then theres the engine, i cant seem to find a mk3 petrol engine on ebay for less than £350, surely i can use a older late mk2 mondeo blacktop as they are more wideley available, cheaper and a better engine that the newer duratecs? the rest of the car is good otherwise.ta
SMILER258
Sep 28, 2015 09:04 AM
