Knocking noise from rear
Old Dec 27, 2010 | 12:22 PM
Ghia-Buckleyn's Avatar
Ghia-Buckleyn
Default Knocking noise from rear
Basically when I'm driving I'm getting a loud knocking noise from the rear drivers side when I'm turning right at slow speeds. Just wondering if anyone can tell what it is, I've been told by a friend that it might be CV joint i just want to know if its going to expensive or not.
Nathan
Old Dec 27, 2010 | 01:25 PM
Sp3no's Avatar
Sp3no
if the noise is definately from the rear it is not a cv joint, your cv joints are at the front
Old Dec 27, 2010 | 02:57 PM
RichieST's Avatar
RichieST
Was gonna say, CV joint on the rear???
Is the knocking constant and relative to road speed? Could be bearing or ARB link?
Old Dec 28, 2010 | 01:45 PM
Ghia-Buckleyn
The knocking noise is quiet when driving at slow speeds but gets louder when i brake or turn right at a slow speed. And yeah it seem to be coming form the rear so its not the CV joint.
Old Dec 28, 2010 | 03:39 PM
blackbeautyzetec's Avatar
blackbeautyzetec
1. are you sure its from the back?
2. if it is the back it will prob the the rear bushes
3. is it a knock or rumble
4. does it pull the car back when it knocks?
Old Dec 28, 2010 | 09:31 PM
Sp3no's Avatar
Sp3no
Jack up the back end of the car, chock the front wheels, release the handbrake and grab the rear wheel at 9 and 3 oclock and try and rock it, if there is any movement what so ever its a wheel bearing thats worn out. Do this to both wheels but generally if you turn left and the noise goes away its the rear right wheel, if you turn right and the noise goes away its the rear left.
Old Jan 5, 2011 | 01:06 PM
Ghia-Buckleyn
It turns out it was a wheel bearing that needed replacing on the rear left.
Thanks for the comments.
Nathan
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
BRAM
Sep 8, 2015 07:11 AM
rsturbo27
Sep 5, 2015 05:08 PM
cossirob
Sep 3, 2015 09:17 PM
