Cossie Brake upgrade for a 51 reg Escort van???
Hello all!
I am new to this forum as I have run Jap cars (Civic, Celica and 3 MR2s) after my last ford (1.6 mk4 Orion GL) 3 years ago.
I have in the last week bought myself "Luther" a white 51 reg 1.8 endura diesel engined Escort van and the brakes are terribly shocking.
Info would be greatly appriciated from you lovely ford fans on weather I could use 4x4 Saph Cossie front calipers with 2wd Cossie discs on the front of my van as like can be done on mk4 escorts.
I have bought some 16" Mondeo Zetec 5 spokes for the van so disc & calipers clearance wont be a problem.
Many thanks in advance!
Cheers, John
Cheers, John
Thanks for the reply mate, Much appriciated.
I think I'll just use the Cossie calipers tho coz I only need to buy discs & pads as I already have the 4x4 Cossie calipers kicking around in the garage.
Also they will only be stopping a 1.8 endura 60hp motor anyway! HaHa!
Thanks again mate!
John.
Thanks again mate!
John.
So.......lol
I went to do the brake conversion today only to find that on a 51 plate Escort van I need a 6mm spacer to sandwich between the hub and caliper mounting space and with the 6 mm plate in place my caliper bolts were 6mm short lol.
I found some bolts to cut down, then realised that I need Sierra front flexy brake pipes due to the fitting being totally different on the Cossie 4x4 calipers to what the shitty van caliper fitment is.
I Phoned Autoparts in Thornaby and ordered some for collection tomorrow morning then found an old Sierra leg in the garage with a Flexy still attached to the caliper! Great I thought for mocking up.
Then it was apparent that the sierra flexy is a male end and the vans is a female end. Doh!
So the big brake conversion is now on hold till get chance to change the front pipework on the van for snazzy new copper brake pipes with the correct fittings for Sierra flexys!
Happy days lol.
I'll let ya'll know how I get on when all the bits I need are in my possession.
Cheers.
Happy days lol.
Cheers.
I got up round 9am yesterday morning and went to Teesside fasteners to get some longer, proper high tensile caliper bolts and washers for spacers (only 4 quid!!) Then around around 1pm I got a call from Autoparts to say the Sierra flexys were in.(12quid each!!!) So I went to pick them up, got some brake pipe and brake fluid while I was there and 42 quid later I had finally got all the bits I needed to crack on. Yeey!
So I got the van in the air, wheels off, took the shitty old calipers and discs off, fabricated two new pipe brakets to attach the flexys and copper pipe to the inner wing as the van ones were totally wrong. Removed the old brake pipes, made two new ones (as my dad has got a brake pipe flaring tool thats older than me! lol) Put on the new discs and Cossie calipers, bolted everything up, tightned all the pipe fittings checked everything over, filled with fluid and blead the system.
Wheels on, all on the ground and fook me, them big ass discs and calipers look super sweet behind my 16" Mondeo 5 spokes compared to the crappy little ones the van was made with! 100 miles or so to bed them in and I'll be laffin!
Just thought I'd share my experience lol.
Cheers all, John
Cheers all, John
Yeah mate, 16" Mondeo Zetec 5 spokes (the cossie lookalike rims)
with a 195/50/16 tyre on so the rolling radius is the same as the 165/80/13 van tyres so accelleration is not altered and the speedo reads about right.
I know this thanks to the etyres website where they have a tyre size calculator!
I don't mate, they will make the rolling radius 12mm smaller than a 165/80/13 and the ones im using are 7mm bigger. When I was using my tom tom the other day my speedo was reading 70mph and the sat nav was reading 65ish so the 7mm bigger tyre diameter should make it more accurate. As a sat nav speed reading is more accurate than a mechanical speedo.
Just thought I'd mention that the tom tom speedo reading was when the van was still on 165/80/13 tyres. So now the speedo should read more accuratly with the 7mm larger rolling radius.(195/50/16)
Red_bull
Aug 9, 2015 08:34 AM
