2.0 Zetec EECV management.
Old Dec 24, 2010 | 02:01 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default 2.0 Zetec EECV management.
on EECV management, the zetec uses the 36-1 set up on the flywheel to determine crank position. Also a cam sensor is used.
Where on the flywheel is the 36-1 gap set up relative to engine position??
also on the cam sensor, what is it picking up and again what relative engine positions are these set to.
im trying to emulate crank and cam positions so i need to know what the sensors pick up and where so i can sync the two sensors correctly with each other.
Old Dec 24, 2010 | 10:21 AM
sailorbob's Avatar
sailorbob
The EDIS VRS pickup is positioned 90° BTDC of cylinder number one on a 4 cylinder engine.
The Cylinder Identification (aka CID) sensor identifies cylinder number one and its position varies according to whether a VRS or Hall Effect sensor is used. For a VRS pickup it is positioned at a nominal 22.5° ATDC for cylinder #1. For a Hall Effect pickup it is positioned a nominal 26° ATDC for cylinder #1.
Old Dec 24, 2010 | 11:01 AM
Psycho Warren
Carbon Crazy
thanks sailor bob.
is the standard cam position sensor on most late 90s fords a hall effect or VRS? would probably rob the sensor off a focus mk1 or similar.
Old Dec 24, 2010 | 11:20 AM
sailorbob's Avatar
sailorbob
The VRS pickup is 'passive' whilst the Hall Effect sensor is powered. When the sensor is picking up a lobe on the camshaft it's usually a VRS. The distributor replacement style sensors (e.g. small turbo Escort Cosworth) are usually Hall Effect.
Old Dec 24, 2010 | 12:00 PM
Psycho Warren
Carbon Crazy
so if i wanted to stick a toothed wheel with one tooth at 22.5 ATDC on a cam sprocket for cam position sensing then a VRS would be adequate? or is it too small to pick up??
Old Dec 24, 2010 | 02:29 PM
focus 4x4's Avatar
focus 4x4
Cant you just fit a standard escort cosworth crank pully?
Old Dec 24, 2010 | 02:42 PM
sailorbob's Avatar
sailorbob
The tooth wouldn't need to be particularly big, the EDIS toothed wheels have fairly small teeth.
Old Dec 24, 2010 | 04:52 PM
cherylfoster's Avatar
cherylfoster
I understand what you want to discuss here and I also believe that our cars use the EEC-V PCM, but it is very similar to the EEC-IV PCM. The electronic controls, sensors, input and output signals are the same.although the maps and tabular data locations may differ in PCM.
Old Dec 24, 2010 | 10:10 PM
Psycho Warren
Carbon Crazy
nah im still on webber management. will fit a 36-1 wheel on front of crank pulley for dash and a single toothed wheel on cam pully at angle sailorbob says.
that is correct yes. plus the introduction of OBDII and ford SCP/canbus data streams.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
